Digital I/O
There must be an easier way to control digital outputs?
My user needs the ability to create and control (on/off) a set of (constant) digital oputputs.
I've come up with the attached VI, but I'm certain there has to be an easier way of doing it.  My only method of creating a constant output is to use a square wave with a 100% duty cycle.
I like to do things right, and I know the solution is out there, though a search of the forums revealed nothing of use.
Any help would be much appreciated.
(3,577 Views)
Yes, that is massive overkill. To put out a constant, all you have to do is use the DAQmx Write set to Single Channel>Single Sample>Boolean. You wire your control directly into the data input.
And either place a small Wait inside the loop so you don't starve the cpu or even better, use an event structure. A value change event for each control would work much better.
(3,574 Views)
Thanks Dennis!  I'm able to get the DAQmx Write to work.
 I think I theoretically understand what you mean by event structure though I've never used it before.  I've gone through the help section and now I'm even more confused.  Would I need 4 separate event loops? or just 4 separate cases? or otherwise?
(3,567 Views)
One while loop with one event structure. You can use a single event and get the CtrlRef to determine which line to set or use a separate event for each control. The latter is the simplest.
(3,564 Views)
