07-09-2008 02:59 PM - modifié 07-09-2008 03:01 PM
Hi Tom,
It depends on whether you want your default state to be logic high or low.
Logic High
Use a pull up resistor. Wire one end of the resistor to the center pin of the BNC connector. Wire the other end to a 5V rail. This will come from an external power supply.
Logic Low
Use a pull down resistor. Wire one end of the resistor to the center pin of the BNC connector. Wire the other end to the ground on the BNC connector.
Let me know if you need clarification on this.
le 01-22-2009 09:09 AM
le 01-22-2009 09:45 AM
Hi Little_Tree,
Actually, you don't need to use resistors at all. Your M-series device supports programmable power-up (default) states. See the following KB on how you can set the default sate of the Digital I/O lines on your device.
http://digital.ni.com/public.nsf/allkb/A98392F93E54D07786256E6F004DE4C3?OpenDocument
le 01-22-2009 10:26 AM
Thanks for that inbelievable quick reply 🙂
Though, I think I do need some kind of proper grounding because I'm experiencing some problems with my triggering. I'm using a counter to watch for a trigger on a line, and I notice it sometimes sees a trigger for no apparent reason. I suspected grounding issues?
le 01-22-2009 01:48 PM
le 01-22-2009 02:27 PM
I'll check the default state of the digital line tomorrow. There is a chance it is indeed not set to low. I'm indeed looking for a rising edge of a TTL pulse. I remember checking the trigger signal and it's a perfect 5V pulse if I remember right. I'll recheck all those things tomorrow at work and I'll report back.
Just to be sure: I only have to set the default state to 0 and connect the inner pin of the BNC connector to the particular line. I do not connect the outside of the BNC to anything...?
Thanks and 'till tomorrow.
le 01-22-2009 07:04 PM
le 01-22-2009 08:02 PM
I don't know exactly what you mean with:
Ideally you would find a BNC cable which would provide a perfect connection for you (with ground referencing).
The connection on the device that is generating the trigger is a BNC connector.
The device I'm triggering (as in controlling with my DAQ card) has also a BNC connector, but that is another story. I suspect I'd apply the same technique to both, so lets just stay with the problem above for now 🙂
le 01-22-2009 08:16 PM
le 01-23-2009 12:48 AM
No apologies necessary. I never explained it very well , so
... there is no BNC terminal on the USB-6251 . Or it must be very well disguised 🙂
http://sine.ni.com/nips/cds/view/p/lang/en/nid/202597
I guess I'll connect the center pin of my BNC connector to the line I'm using to watch for a trigger. The outer shell to the Digital Ground. Correct me if that's not the way to go.
