02-27-2014 08:37 AM
I have an application that is very sensitive to capacitance and wondered if anyone knows what the input capacitance of the PCIe-6537 is?
Nick
02-28-2014 06:18 AM
Hi Nick,
The capacitance of any NI HSDIO device and cable combination is dominated by the capacitance of the cable, as the input capacitance of the HSDIO device channels are minimal.
The PCIe-6537 device capacitance is determined by the buffer component before the output and input. You can find the buffer part number on the actual PCIe card on the side. The ones used in this device are NC7WZ126 TinyLogic UHS Dual Buffer with 3-STATE Outputs from Fairchild Semiconductor. You can find the link to the datasheet here: https://www.fairchildsemi.com/ds/NC/NC7WZ126.pdf
If you scroll down to page 3 of the datasheet you can see from Cin, Cout and Cpd values that the capacitance per channel will vary between 4 and 10 pF.
Hope that helps.
02-28-2014 07:40 AM
Hi Mark
Thanks for the quick reply, that helps a lot. Do you have any info on the cable capacitance?
Thanks again,
Nick
02-28-2014 08:55 AM
No problem at all.
A default SHC68 cable will have a capacitance of approximately 100pF (that's including the connector leads as well).
02-28-2014 02:45 PM
The input also has 40ohm resistor in series, and then around 12pF to GND, in parallel with a 50Kohm, so the equivalent model looks like
1m VHDCI cable capacitance is around 100pF
