05-18-2007 02:39 PM
05-21-2007 12:41 PM
Hi Arunabh,
Did you have a 6534 which was previously working with the same program?
I followed what you did, beginning with the example program and then using a waveform and did not get any errors. (See picture attached). I would note that the datasheet says:
You have the following restrictions when looping from the onboard memory of the NI 6534:
• For 8-bit data, the buffer size must be a multiple of 4.
• For 16-bit data, the buffer size must be an even number.
There are no restrictions for 32-bit data. For 8- or 16-bit data, you may need to add dummy data to the buffer to make it the correct size.
Also, can you post pictures showing me the rate and the inside configuration of the DAQ assistant?
05-21-2007 02:51 PM
05-22-2007 01:36 PM
05-22-2007 05:16 PM
Arunabh,
Here is the picture I meant to post last time (Cont. Write_Edited.JPG). This issue does not arise with the 6533, which is why you did not see it before. Also, if you are using LabVIEW 7.1 or above, I would like to ask that you upgrade to DAQmx 8.5 for Windows XP. After upgrading, please do not use previously placed DAQ assistants, but place down new ones. I could not reproduce your issue by simply creating a continuous output DAQ assistant, and putting in a digital waveform generator for data. (6534_continuous_daq_assistant.JPG).
05-23-2007 03:47 PM
