05-21-2007 07:01 PM
05-22-2007 03:09 PM
There isn't an XP registry key that you can modify to increase the block size. However is there any reason why you are trying to output 22 million samples all at the same time? You could try to stagger it so that you send the data in bursts instead.
I am testing you code right now and will let you know how that goes.
05-22-2007 04:34 PM
05-22-2007 04:35 PM
05-23-2007 10:10 AM
Carlton,
You will need to modify the example so that you perform multiple writes instead of just one. If you chunck up your data into smaller pieces you will use less bandwidth in the data transfer.
If you call DAQmxWriteDigitalU32 with your data in chuncks you should be able to get rid of this error.
05-23-2007 11:52 AM
Hello Abhinav T.,
I will try the data chunk method.
Do you have any hint on the maximum data chunk size?
I can try a number of sizes but is there any official word on the recommended data chunk size?
Carlton.
