03-18-2013 01:37 PM
I'm currently attempting a project in which I need to trigger a square wave output through the 9041.
The trigger is an "if" statement with-in my coding & dependant on the result this changes the duty cycle so that I can control a motor through PWM.
Originally I had intended on creating a digital output through one of the example files on the system ( Example Finder> Hardware Input Output> DAQmx> Digital Output ) & then gaining an understanding of how that one worked & creating my own.
However, even using the example "Digital - Continuous Output.vi" I am yet to see any sort of signal on my oscilloscope which I have the 9401 hooked up to.
I'm using the file as it stands, setting the lines to "cDAQ1Mod3/port0/line0", setting the clock source to be onboard the cDAQ (/cDAQ1/ai/StartTrigger) & seeing nothing.
I'm having some luck using the "Counter - Finite Output.vi" example but this is just giving me rising and falling edges which I assume are to be used as triggers.
Any ideas where I can start with this would be much appreciated.
03-19-2013 09:31 AM
Hi crumpetnibbler,
Am I correct in thinking that you require a PWM output which allows you to change the duty cycle 'on-the-fly'?
The following White paper describes methods of outputting PWM signals using DAQmx and also has examples which include the functionality to trigger and alter the PWM duty cycle:
http://www.ni.com/white-paper/2991/en
I have tested this with a 9401 and have successfully generated a PWM signal.
Please note that DIO0 does not necessarily relate to ctr0 output. In order to see which pins should be connected, you can right-click the hardware in MAX and select Device Pinouts.
Please let me know if I have made any incorrect assumptions of if you have any further questions on this.
03-20-2013 01:31 PM
I could kiss you right now.
I haven't had a chance to test it because the only chassis I have available to me was in use but if you managed to get it working with a 9401 then I know it's possible & I'll just keep at it until I get it working.
I assume I just alter the "Counter(s)" parameter to be the pin output that I need & I can change the duty cycle as the program goes.
Thanks again, I'll report back when I get a chance.
03-22-2013 07:32 AM
Hi Chris,
I've got the PWM program from the White paper working but when I hook it up to an oscilloscope I am not seeing a square wave, instead I'm seeing the following (apologies for the picture quality & unfocused reading on the scope, someone changed the settings while I was away)
The trailing edge moves when I alter the duty cycle so it works in that sense, I just assumed I'd be looking at a square wave. Is this correct or have I managed to go wrong somewhere?
Many thanks for any help,
Josh
03-24-2013 03:11 PM
Try settting your scope input for DC coupling. It looks like you have it on AC.
Good luck,
Dave
