Digital I/O
Need help with USB-6525 Change Detection
    I wanted to make a program to read only when there is a rising edge on the USB-6525.
    Something like what an Event structure does, to execute only when there is a rising edge. I wanted to detect a "change event".
    But the code doesn't behave this way. it executes on every iteration of the loop.
I wanted to detect a "change event".     But the code doesn't behave this way. it reads data on every iteration of the loop.
Can anyone advise how to code the program so that it will read the data only when there is a change event in the signal?
Thanks for any help.
Regards
(4,141 Views)
6525 doesn't support change detection as shown in https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAqXSAW&l=en-US
You probably read boolean, and keep in shift register to detect the change between loop, and update to indicator, but the loop will execute independent of logic level.
(4,128 Views)
Hardware capability is the first thing that I have checked. It is clearly stated in the product description that change detection is supported for USB-6525.
Can NI comment/advise? misrepresentation?
Regards
https://www.ni.com/en-us/shop/model/usb-6525.html
http://sine.ni.com/ds/app/doc/p/id/ds-137/lang/en
Some highlights are listed for easy reference
Industrial feature set including change detection, power-up states, filters, and watchdog timers
Trigger Your Application with Change Detection
With change detection, you can automatically trigger your software application to perform a digital read operation upon a digital change of state.
Using NI-DAQmx software technology, the USB-6525 notifies the software application when it detects an event, causing the application to automatically perform a read operation.
(4,117 Views)
Accepted by Limsg
6525 change detection support is added in DAQmx 8.9.
You can download latest DAQmx from https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
(4,112 Views)
Thanks for the info.
Well.. another 1.1GB download......
Wouldn't it be more user-friendly to provide individual components for download.
Easier for deployment also..
(4,100 Views)
