Digital I/O
NI 9425 Digital Input Module
Hi, Could somebody please advise myself on the following: I am planning on using the c series module 9425 with a compact RIO to detect 24V DC signals from various devices. Can I simply connect the DI pin to the positive terminal of a 24V + supply and the COM pin to the 0V of the 24V supply? Will the card then detect when the voltage is turned on and provide a path from the DI pin too the COM pin thus compelting the circuit. Or would I have to connect to the card in a different way? Regards Robert Foat
(6,034 Views)
Accepted by topic author RobF
That module is made for 24V logic.  So yes, you can just hook up your voltage straight to the inputs.  It was provide a 30kOhm resistance to ground (input impedence in the spec).  It is generally not a good idea to count on a digital input to complete a circuit.  The digital input should be more of a sense.
(6,031 Views)
Thank you for your quick reply, as you said the 9425 will be used as a sense input and will not be used to complete the circuit.
(6,027 Views)
