Digital I/O
Measurement & Automation doesn't detect my USB-6501
I have installed NI-DAQMX BAse software on a PC.
When I connect my USB-6501, I doesn't see my USB-6501 with the program "Measurement & Automation ".
The Windows2000 Hardware Device Manager detect the USB-6501.
I am not administrator on that PC.
(3,392 Views)
You have to use the Daqmx Base configuration Utility in Start> National Instruments> Daqmx Base.
You can also not use the Daq Assistant which is supported by daqmx not by Base.
Regards.
JV
(3,381 Views)
