 Sach
			Sach
			10-19-2006 01:56 PM
10-20-2006 10:47 AM
10-31-2006 04:05 PM - edited 10-31-2006 04:05 PM
Message Edited by Sachinj on 10-31-2006 04:08 PM
Message Edited by Sachinj on 10-31-2006 04:09 PM
11-01-2006 12:44 PM
11-02-2006 03:56 PM
		11-03-2006
		10:37 AM
 - last edited on
		05-28-2024
		10:02 AM
 by
		 Content Cleaner
			Content Cleaner
Hi Sachin -
The 6533 isn't designed as a pattern generator, and so it lacks many of the features you're looking for.  It is meant to be a digital communication device.  It lacks the feature to adjust phase (or offset from the sample clock).  You can adjust generation frequency by simply changing the sample clock rate, which is a connector on the front panel of the VI.
I recommend that you consider using one of our function generators instead.  These devices are deisgned specifically to the task you describe, and they carry every feature you've requested.
If you plan to continue using your DAQmx-based device, I recommend checking out our new Getting Started with DAQmx page. It's been categorized and expanded to teach both basic information and advanced techniques.  It's a great resource when the Help documentation and shipping examples aren't quite enough.
 Danielkks
			Danielkks
			03-07-2007 12:20 AM
Hello David,
Came across your post in my search which is pretty close to my application.
Can i control the number of pulses to generate through this HW?
Daniel
03-07-2007 03:43 PM
