02-20-2008 12:21 AM
02-20-2008 08:24 AM
02-20-2008 02:59 PM - edited 02-20-2008 02:59 PM
Hi Ravindhra,
What Dennis says is correct. You can download and install the NI-DAQmx driver from ni.com. On the webpage, click on the Support tab, select Drivers and Updates, and search within results for NI-DAQmx. When you follow the instructions and install the driver, Measurement and Automation Explorer (MAX) will be installed too.
After MAX is on your computer, you can open in by going to Start>> All Programs>> National Instruments>> Measurement and Automation.
Simulating a DAQ device can be done in MAX’s Configuration Tree found on the left. First expand My System>> expand Devices and Interfaces>> right click on NI-DAQmx Devices>> select Create New DAQmx Device>> then select NI-DAQmx Simulated Device as seen in the attached screenshot. This will allow you to simulate almost any DAQ device that you are interested in using. Like Dennis said, any task you configure for the analog channels will return a sine wave.
Hope this helps, Mallori M.
