Digital I/O
I am recieving error showing niajel.dll missing for HSDIO in labVIEW 2010, Can anyone help how to solve this.
I am using LabVIEW 2010 and installed LV2010 device drivers and trying to use HSDIO functions, While placing HSDIO function on the block diagram it showing niajel.dll is missing, Can anyone help me in fixing this bug.
I tried uninstalling and installing many times not able to fix.
(5,246 Views)
I have some questions to ask to help us understand some of the surrounding circumstances for this issue.
  • Can you verify the driver version of HSDIO that you are using?
  • What OS are you on? 32-bit or 64-bit?
  • Are you using any other versions of LV on this machine?
  • Is this the first time you've encountered this issue? Was it working before you installed LV 2010 drivers?
  • What HSDIO hardware are you using?
Thank you.
Kyle A.
Chief Applications Engineer
(5,233 Views)
Accepted by topic author Somu26
Hello. niajel.dll is related to NI-TClk although NI-HSDIO does not use it specifically. Are you using some TClk functions?
Also, what other PXI device driver are installed on the system? Could you give a MAX system report?
Brian Morgan | NI Software Engineer, R&D
(5,228 Views)
thank you, Kyle for your response:
answers to you questions.
I am using HSDIO 2.0
OS is 64 bit
I am using LV2010 and LV2012 32 bit
Previously it was working fine with 1.9.0 and while updating to 2.0 it is showing some error.
PXI 6556
attached Error information for reference.
Tried uninstalling 2.0 and installing 1.9.0, In 1.9.0 also now it is showing same error in all the labVIEW versions.
What is niajel.dll where it is located?
(5,226 Views)
Hi Brian,
Please find the attached report,
(5,223 Views)
Brian Thank you,
After upgrading NI TClk, the issue resolved.
Kyle Thank you for looking into the issue.
(5,173 Views)
