Digital I/O
How to write data into groups using list pattern
Hi guys, Im so glad i found this forum, I have searched for an answer to this , can anyone enlighten me please...I am using LabVIEW. I configured the ports for group configuration for each port, then I tried to do group writing, i think im missing something easy but how do i use the written list pattern and the index array to write data into the DIO6533 groups
(3,627 Views)
Hello hybrid01
I am an applications engineer at National Instruments and as I understand you are having problems with your LabVIEW code and grouping data with the list functions.
Would it be possible for you to post your code so that I can have a closer look at what you are trying to achieve? When you attach your code could you please make sure you have attached any sub vi's and ctl that I will need to run the program. It would also be useful to document parts of the code.
I have found an example online which may help you to continue your development in the meantime.
LabVIEW:  Writing a String Array to a TDM Channel Group Property
Please have a look at this example and let me know if you make any progress.
Regards
Stephanie L
National Instruments UK and Ireland
(3,599 Views)
Thank you so much , it was just the simple string array i was having trouble getting the formta to show coorect but your link helped me, I think the problem is sorted now, i will check the context again and get back and post more details if i still have the problem, thanks again for your help, much appreciated
(3,592 Views)
