‎07-08-2011 12:47 AM
‎07-12-2011 08:21 AM
Hello hybrid01
I am an applications engineer at National Instruments and as I understand you are having problems with your LabVIEW code and grouping data with the list functions.
Would it be possible for you to post your code so that I can have a closer look at what you are trying to achieve? When you attach your code could you please make sure you have attached any sub vi's and ctl that I will need to run the program. It would also be useful to document parts of the code.
I have found an example online which may help you to continue your development in the meantime.
Please have a look at this example and let me know if you make any progress.
‎07-12-2011 09:48 AM
Thank you so much , it was just the simple string array i was having trouble getting the formta to show coorect but your link helped me, I think the problem is sorted now, i will check the context again and get back and post more details if i still have the problem, thanks again for your help, much appreciated
