Digital I/O
How to create and send digital trigger?
"I have to create a digital signal with matlab."
This is a National Instruments forum, if you want to know how to create a digital waveform using Matlab my suggestion is to check out other forums.
Anyway you can do it, you can use an external signal as trigger for your acquisition.
Kind regards.
Message 11 of 15
(2,119 Views)
A digital trigger is a physical signal. I have no idea about matlab but it does not sound like you are doing anything correctly. If you are using matlab to tell the DAQ card to output a digital signal, you can simply start the acquisition with a software command. No adware trigger is required.
Message 12 of 15
(2,116 Views)
I use matlab to create the trigger but I can use another program like it. But I can't use LABVIEW so I asked how can do it. Thank you!
Message 13 of 15
(2,106 Views)
You aren't making any sense to me. No software alone is capable of generating the trigger. I don't know why I have to keep repeating that you have configured your data acquisition to start when a hardware signal is present. Why you are incapable of explaining why you need a trigger in the first place is a mystery. You cannot explain what the conditions are supposed to be when a hardware trigger is generated.
Since you have done trouble understanding English, post in your native language, preferably on a forum dedicated to that language.
Message 14 of 15
(2,104 Views)
Ok, I'm sorry!
Message 15 of 15
(2,099 Views)
