Digital I/O
Help in PWM
Hello all
I'm quite new in using Labview and I need help to generate PWM with frequency 20 kHz and changeable duty cycle
I need generate this PWM via  digital I/O NI 9403 and cDAQ-9184....
thanks
(4,224 Views)
I think Figure 3 in this article would work for you: http://www.ni.com/tutorial/2991/en/ .
Douwe
(4,187 Views)
thanks bro for your reply but the attached links include PWM with counter port i only have digital I/O port
(4,180 Views)
Oops, my bad. I should have checked the module type first. In your case, the information in my other post applies that I posted just yesterday in this same forum. I have attached a test vi that generates 20,000 samples per second and updates the signal (duty cycle if you wish) every 500ms. I wrote it for a 9401 module in a 9184 chassis, but I think it'll work the same for the 9403 module.
The code isn't pretty (one of the loops doesn't even have a way to be stopped, ha), but you'll get the idea of how to do the digital write.
Douwe
(4,169 Views)
thanks so much for your reply bro
i cant open the VI file  i have labview 2013 your labview version looks latest
could you send me the file again, Please?
(4,161 Views)
Here it is for LV 2013. Let me know if this works for you.
(4,158 Views)
thanks bro
actually it not work  i still trying to identify the problem
(4,117 Views)
