Digital I/O
Generate continuous samples with ni 6229
Hello Jason,
Thanks for your helping, from now I can generate continuous digital signals. However, I just aware of that, when I would like to change the frequency, I does not make sense on the oscillascop. It is always in same frequecy.
Could you please help me about it?
Thank you,
Best Wishes,
Selcuk
Message 11 of 23
(2,868 Views)
Could someone help me please about that subject? I need to do this asap..
Thank you,
Selcuk
Message 12 of 23
(2,856 Views)
Hi Selcuk,
What is your current setup? What channels do you have your counter and DO coming out of? Are you sure your oscilloscope isn't automatically adjusting for the changed frequency?
Kind Regards,
Jason
Jason W.
Applications Engineer
National Instruments UK & Ireland
Message 13 of 23
(2,853 Views)
Hi Jason,
Thanks very much for your interest.
I attached the figures of my setup. Besides figures, I connected the PFI12 to PFI1 via a wire and I set it up to  clock source advanced timing of digital output as a PFI1 . Also, about the oscillascope, it displays the correct frequecy,
therefore we have tested the frequency effect on the motor, unfortunately we could not observe any changing on it.
 Hopefully, figures and definings will help.
Thank you,
Best Regards,
Selcuk
Message 14 of 23
(2,849 Views)
Could anyone please help me about frequency changing problem? I am changing the frequncy in signalexpress for digital outputs but it does not make sense.
Thank you,
SA
Message 15 of 23
(2,811 Views)
please help me!!!!!!!!!!!
Message 16 of 23
(2,794 Views)
Hi Selcuk,
I've been looking at this myself in SignalExpress and you can't change the frequency of the digital output task. In order to change the frequency you have to modify the sample rate in the Create Digital Waveform step. Try modifying the sample rate in that step and see if that changes the results.
Kind Regards,
Jas.W
Jason W.
Message 17 of 23
(2,792 Views)
Hi Jason,
The changing sample rate does not make sense on the frequency. Do you have any other idea? Maybe I need to convert this program to Labview classic. However, this programme is quite complicated for me to convert it to Labview classic.
Selcuk
Message 18 of 23
(2,782 Views)
Accepted by Emraisel
Hi Jason,
I think that analog cont signals and digital one sample signal are enough for me for that time,however, it gives a warning;
Warning 200015 occurred at DAQ Assistant
Possible Reason(s):
Measurements: While writing to the buffer during a regeneration, the actual data generated might have alternated between old data and new data. That is, while the driver was replacing the old pattern in the buffer with the new pattern, the device might have generated a portion of new data, then a portion of old data, and then a portion of new data again.
Reduce the sample rate, use a larger buffer, or refer to documentation about DAQmx Write for information about other ways to avoid this warning.
 I would like to ask you another question: How can I control the sending  signal for analog continuous signal in signal express?  For example I would like to
 send only 50 sample for each loop. or can I use a formula which is controlling the sending data number?
Please let me know which command will be able to do this.
Thank you,
Selcuk
Message 19 of 23
(2,772 Views)
Could you please someone answer my questions?  Replying time is quite so long. Please!!!!!!!!!
Message 20 of 23
(2,742 Views)
