Digital I/O
Frequency measurement off USB 6343
I have frequency measurement from a flowmeter, and I would like to acquire data on my DAQ system. Is it possible to do it through a digital I/O channel? Could you please advise a method, or example?
(2,928 Views)
Hi vahid590631,
Choosing between making the frequency measurement on digital or analog channels will depend on your flowmeter signal output. You can make a frequency measurement with either analog or digital channels but digital will be easiest. The best examples for this can be found in LabVIEW under the example finder. To find these, open LabVIEW and go to “Help>>Find Examples…>>Hardware Input and Output>>DAQmx>>Counter Input”.
Also, here is some general information on frequency measurements that you may find helpful:
https://www.ni.com/en/support/documentation/supplemental/21/frequency-measurements-how-to-guide.html
Nolan H.
(2,892 Views)
Hi  NoHeart43
Thanks for your advice.....
(2,872 Views)
