I want to run 20 digital outputs for a distance of around 10 meters from my PCI 6509 DIO card, to drive some relays. How can I effectively do that. Are there any other alternatives. Can some electronic circuit be implemented in between?
The problem is, there is no isolation provided. Since this is a PCI card, I don't want to use this on Ethernet either.
Now, since the distance is so high, there will definitely be a problem with the analog input and output as well, how should this be taken care.
Any suggestion is welcome.
Sreedhar T
Sreedhar T
