Digital I/O
Controlling two solenoid valves using NI 9482 Relay
Hello, I just started this time-sensitive project last week (and began using LabVIEW at the same time) and I am looking for help to control two solenoid valves using an NI 9482 relay and a cDAQ-9172. I would like to run my program for a set (variable) amount of time (probably about 3 sec). Half a second after starting, I would like my first solenoid valve to open, and then a certain amount of time after that I want my second valve to open. I would like them to remain open until the program has run for the set amount of time, then I want them to close at the same time at the end of the program's run time. I am looking for advice on the simplest way to perform this using LabVIEW. Thank you.
(3,716 Views)
Hello KarH, I recommend using the LabVIEW examples (Help -> Find Examples -> hardware input and output -> DAQmx) there you'll find examples that fit for this.
Also, keep in mind that this device needs an outside power source, check page 10 of this document https://www.ni.com/docs/en-US/bundle/ni-9482-sbrio-9482-specs/resource/ni-9482-sbrio-9482-specs.pdf and the sample rate is 1 S/s meaning this is the fastest rate you can open/close the relay.
Seeing you are new with DAQmx, I highly recommend this document https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl..., it's possible you find enough information to start your project.
PedroR
(3,662 Views)
Thank you for your response. I actually figured it out yesterday using examples.
(3,659 Views)
