Digital I/O
Can you pull the OC outputs to 3.3 instead of 5.0 on the 6533 D I/O board?
Can you pull the open collector outputs on the 6533 Digital I/O board to 3.3 volts instead of 5.0 volts? It seems from the specs that 3.3 volt inputs will function properly, anybody have experiance with this?
(3,169 Views)
Hello BMEWOLF,
Logically, 3.3V would work since it is still a high TTL speaking. There is no guarranty though since the board was built considering that those pins will use 5V.
(3,155 Views)
