Hi Quark32,
To answer your question, the PC-DIO-24 cards can run on win2k platforms.
When you say recognize, do you mean viewing it in Measurement and Automation Explorer (MAX), or do you mean having windows recognize the card in device manager? If you are having trouble seeing the card in MAX, I would make sure you are refreshing your view every time. If this does not work, then try using the latest available driver. It can be found
here. Lastly, I would try installing the card on another machine running Win2k to see if it can be recognized there. Hope this helps!
Jeremy L.
Jeremy L.
