Digital I/O
AT-DIO-32HS driver
Can't find a driver for the 32HS. My NI-DAQ CD only has 32F
(3,404 Views)
Got my own answer. Since this is a plug-n-play card, I needed to follow the suggestions in the NI-DAQ help for adding a device under Win NT, then reboot. Don't need to select a device to add.
(3,404 Views)
Hello;
You can download the latest NI-DAQ driver available from www.ni.com, free of charge.
You won't need to specifically select the DAQ device, since that board is a plug and play device.
Hope this helps.
Filipe A.
Applications Engineer
(3,404 Views)
