02-10-2010 04:25 AM
I am using Agilent 34952A module in 34980A Multifunction SW/Meas. Unit. I read the informations about "using third party products" and applied them. In driver session part, there exists two files both for 34980A and 34952A. I created driver session and logical name for 34980A. But for 34952A, in the driver session part, I selected 34952 and nothing(IviSwtch & IviDriver) appeared on provided API section but appropriate product appeared as 34980A. Nevertheless, I created driver session&logical name. And it gave no error. However, I couldn't see DIO, totalizer on the screen. How can I achieve this problem?
Solved! Go to Solution.
02-11-2010 02:27 PM
Ebru,
Are you using LabVIEW or LabWindows/CVI to program this instrument? Are you using this instrument driver? When you say that you look at a document about using third party products can you link me to that document or provide me the address so that we can be on the same page?
Are you looking to control your device with your own IVI based controls or a prebuilt project and VIs like in the driver I linked above?
02-12-2010 01:00 AM
02-12-2010 09:28 AM
I'm confused as to what you are doing. The switch executive will support the 34980 with the appropriate modules (i.e. scanners, muc, etc) but I don't see how it would support the digital I/O module as it is not part of the switch class. Frankly, I'm not sure the digital I/O fits into any IVI class.
NI Switch Executive would be used with other programs such as TestStand or LabVIEW. What master program are you using? From there, you should be able to call into the 34980A specific driver and control the digital I/O.
02-12-2010 01:53 PM
02-13-2010 02:36 AM
