Digital I/O
6513 and Switch Executive
I'm using several digital output modules type 6513. The modules are used to control external small signal relais (fixed and variable allocation).
Is there any chance to get this modules switched by Switch Executive or to integrate it to the switch functions of TestStand (Properties -> Switching)?
Thanks in advance!
Martin
(3,385 Views)
Hello Martin,
the direct switching capabilities of TestStand are based on the IVI-Switch functions. Unfortunately, the 651x series of digital output cards do not support IVI functionality.
The best way to control these digital output cards would be to write a set of LabVIEW VIs which use the DAQmx driver functions to control the relay switching, and call these VIs as LabVIEW action steps in TestStand.
Sebastian
(3,364 Views)
