DigiMetrix
Do I need a digimetrix license for every PC I deploy an application to ,containing the DRL VIs?
I created an application using the DRL VI library. When I create an installer, deploy it on a remote PC and try to run it, I'm prompted for imaging software DRL license activation. Do I need a license for every deployment of an app. containg this library? If not, is there an additional installer I need to include in my installer build? I looked over the list of the additional installers and did not see anything with the words Denso, Imaginglab, or digimetrix in the name.
(8,928 Views)
Helo cjrsupertech,
Yes, you need to have a separate license for every machine (PC or NI RT-target) that uses DRL VI's and communicates with a robot (from LabVIEW and/or from an application).
DigiMetrix robotics library serves you as an additional LabVIEW toolkit. Unlike other additional LabVIEW modules and toolkits DigiMetrix libraries do not use separate Development and Run-Time licenses. Instead libraries use a different scheme where license is moving with a robot (or robots) connected to the PC or LabVIEW Real-time target, on which robot application is actually running. This PC and LabVIEW Real-time target are called PC target and RT target accordingly.
Every purchased license includes the following:
  • One PC target license
  • One RT target license
Kind regards,
Nikita.
Nikita Prorekhin
CLA
(8,919 Views)
