Developer Center Resources
Calling Python Code from LabVIEW
This VI sends inputs to a simple Python script, and returns its output.  The basic method could be used to call code from many different languages, like Python, Perl, and Tcl.
Requirements: LabVIEW, Python
Instructions
  1. Download the simple Python script AddNumbers.py attached below.
  2. Download Calling Python Script.vi (or the PNG code snippet).
  3. Place the Python script and the VI in the same folder (this is simply expected by the example, and could be changed).
VI Details
  1. Build path to Python script, which is expected to be in the same folder as this VI.  Again, the Python script could be moved, but the code would have to reflect that change.
  2. Create the command line argument, in the form of pythonpath scriptpath int32 int32.  Quotation marks are used for the path, in case there are spaces.
  3. Execute the  argument.  The run in minimized, so that the command window does not quickly appear and disappear.
  4. Convert the string output from Python to an int.
Chris Bolin
LabVIEW Partner Program, CLA
Comments
Tom_Hawkins
on
This isn't really any more than an example of how to use System Exec, though I suppose that'll be useful to some people.
What happens if I want to pass parameters to a Python script that contain spaces or reserved characters - is there an easy way to make sure they get quoted or escaped correctly or is it up to the LabVIEW programmer to figure this out?
PrimaryKey
NI Employee (retired)
on
Or you can use this toolkit https://forums.ni.com/t5/LabVIEW-APIs-Documents/Open-Python-Interface/tac-p/3613384#M228
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
carrasquel
on
Hello everybody I just did a new entry on my blog about an alternative on how you can integrate Python and LabVIEW
http://bit.ly/2pMSARJ
If any question or doubt don't hesitate to comment or contact me 🙂
AWK073
on
PrimaryKey
carrasquel
both links are not opening which you guys have given above.
carrasquel
on
Contributors
