‎02-27-2015 06:45 AM
after working through the example for "Third-Party Licensing and Activation Toolkit" with "Simple Math" all done well. So I tested it with one of our own toolkits. It seemed to work fine but after trying to open the created licensed lvlib I got the message "Project or Library file is corrupt.".
Any ideas?
Peter
‎02-27-2015 09:06 AM
Got the problem solved. After comparing the lvlib files (licensed & unlicensed) I found that the containing .mnu lines where different. I removed them from library and could start the licensed lvlib without problems.
‎02-27-2015 10:19 AM
Thank you for the update. Were the .mnu lines modified during the license binding or were they incorrect in the source library file as well?
-R
‎02-27-2015 10:39 AM
This was the difference between the lvlibs, original to the right, licensed to the left:
