DQMH 3.1 Only inserts the Delacor examples directory into TestStand Search Directories once
We just released DQMH 3.1 which includes some updates to the toolkit.  You can see the release notes here: http://delacor.com/dqmh-documentation/dqmh-3-1-release-notes/
We realized that the TestStand examples that ship with the toolkit were inserting the Delacor Examples directory at the bottom of the TestStand Search Directories every time the sequence was loaded. We were using the Search Directories.Insert method, and it turns out this method inserts the directory without checking if it is already there.  The video below describes the issue and how we solved it on DQMH 3.1.
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(5,154 Views)
Added an idea for the insert method to not duplicate directories: http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Search-Directories-Insert-method-should-not-dupli...
If you agree, please vote for the idea.
Fab
(5,136 Views)
