NI TestStand Idea Exchange
About NI TestStand Idea Exchange
Do you have a feature idea for how to improve NI TestStand? Submit and vote on ideas now!
  1. Browse by label or search in the TestStand Idea Exchange to see if your idea has previously been submitted. If your idea exists sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea. Be sure to submit a separate post for each idea. Note: the TestStand Idea Exchange is not the appropriate forum to submit technical support questions.
  5. Give kudos to other ideas that you would like to see implemented!
The TestStand R&D team is committed to reviewing every idea submitted via the TestStand Idea Exchange. However, we cannot guarantee the implementation of any TestStand Idea Exchange submission until further documented.
Top Kudoed Authors
Search Directories Insert method should not duplicate a search directory
The Search Directories.Insert method should only insert the directory if it is not already there.
The Method includes an index argument, if the directory is already there, then it should move the existing directory to the requested index.
While we were working on the shipping examples for DQMH, we discovered that the insert method was creating duplicates every time it was called. We implemented a work around that includes a for loop to check each of the items in the search directories list to see if it is the directory we are trying to insert, if it is, we delete it. Once the for loop ends, then we insert the directory where we want it.
You can see a video of the issue and how we worked around it here: DQMH 3.1 Only inserts the Delacor examples directory into Search Directories once
Certified LabVIEW Architect * Certified Professional Instructor * LabVIEW Champion
