DIAdem
transparent chanel line
Hello together,
regarding Diadem2022 report.
Is there a possibility to make a channel line transparent in order to make overlapping channels visible?
Greetings
(489 Views)
Not sure what the intention is, but you can set either curve color to 'no color' or line style to empty. In both cases the line is not drawn. Or you can unset the 'display curve' option. If you need any other behaviour an example would be helpful to understand your needs.
Holger Müller
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
(449 Views)
thank you for reply.
I'm only searching for a solution to make channel lines transparent.
reg. example:
in our application we want to show many different measurement data in 2D diagram.
Sometimes measurement data have a lot of background noise and hide other channels.
Greetings
(419 Views)
