DIAdem
Matlab Plugin Error 6204
Have installed the Matlab Plugin version 21.0 for both DIAdem 2021 and the newest DIAdem 2025 Q2. Using a HP Elitebook x360 G11 with Windows 11. On both DIAdem versions I am not able to store data in .mat-format. Always getting the error that the file is incomplete. Error code 6204. Someone with a similar issue or solution?
EDIT: It works fine with the DIAdem Example-file. So this one can be stored in Matlab format. Is there any limitation to how many channels / channel size can be exported to MAT?
Message 1 of 1
(293 Views)
