DIAdem
standard deviation
I have 4 force channels that i have to find standard deviation for at each point. So basically, i find average at each point, substract it with the value at that point in force, sum it, divide it by 3 and then squareroot it. I have to do this for every point. I dont think Diadem has an in built function to do this so i did the following but i get errors:
L1 = GLOBUSEDCHN+1
CALL CHNAVERAGE("FCHNS(1), FCHNS(2), FCHNS(3), FCHNS(4)", L1) '------> error says it cant average it because only one Y channel is present.
CN(L1) = "FAVG"
CC(L1) = "FORCE AVERAGE"
L1 = GLOBUSEDCHN+1
FOR I = 1 TO FLENGTH
L2 = I
AVF = CHDX(L2, CNO("FAVG"))
CHDX(L2, L1) = SQR(((CHDX(L2, L3) - AVF)^2 + (CHDX(L2, L4) - AVF)^2 + (CHDX(L2, L5) - AVF)^2 + (CHDX(L2, L6) - AVF)^2)/3)
NEXT
CC(L1) = "STANDARD DEV - FORCE"
CN(L1) = "STDFORCE"
when i do the last part it makes a channel with the values in it but i cannot access it. It says the channel length for it is 0 but ti should be flength. Anyone knows how to fix this or even better find a better way to do this?
Lemme know. Thanks Shefalika
(5,007 Views)
oh i dont know if it matters - i am using diadem 8.1. Thanks.
(5,000 Views)
Hi Shefalika,
I developed and checked the below VBScript in DIAdem 8.1-- yes, it does matter.  Your resultant calculation will run much faster and more efficiently by programmatically using the Formula Calculator.  You also needed to pass the channels to the ChnAverage() function as a channel string.
Dim FChns(4), ChnStr
FChns(1) = 1
FChns(2) = 2
FChns(3) = 3
FChns(4) = 4
ChnStr = FChns(1) & "," & FChns(2) & "," & FChns(3) & "," & FChns(4)
CALL ChnAverage(ChnStr, L1)
L1 = CNo("Mean_values")
CN(L1) = "FAvg"
L3 = FChns(1)
L4 = FChns(2)
L5 = FChns(3)
L6 = FChns(4)
FormulaTxt = "Ch('StdForce'):= Sqrt("
FormulaTxt = FormulaTxt & " (Ch(L3)-Ch(L1))^2 + "
FormulaTxt = FormulaTxt & " (Ch(L4)-Ch(L1))^2 + "
FormulaTxt = FormulaTxt & " (Ch(L5)-Ch(L1))^2 + "
FormulaTxt = FormulaTxt & " (Ch(L6)-Ch(L1))^2)"
Call FormulaCalc(FormulaTxt)
L2 = CNo("StdForce")
CC(L2) = "STANDARD DEV - FORCE"
Ask if you have additional questions,
Brad Turpin
DIAdem Product Support Engineer
(4,972 Views)
Brad I hate to thread resurrect but with newer versions of DIAdem is there a function that does this?
I am looking to calculate STD DEV is the same format as the OP but I also need a +/-3 sigma
Tim
(3,678 Views)
Hi Tim,
For many versions now, DIAdem has had a "Standard Deviation" checkbox in the "Descriptive Statistics" ANALYSIS dialog in the "Statistics" palette.  Recent DIAdem versions also have "Three Sigma" and "Six Sigma" checkboxes.
Have you looked at the Statistics options lately?
Brad Turpin
(3,648 Views)
Brad
My version of DIAdem 2017 sp1 only has "Standard Deviation" checkbox.
Do the newer versions have Three and Six Sigma?
Tim
(3,641 Views)
Hi Tim,
That's actually sufficient, you can multiply the "standard deviation" result by 3 to get "Three Sigma" and by 6 to get "Six Sigma".
Here's what it looks like in DIAdem 2018,
Brad
(3,638 Views)
