DIAdem
"Could not create Script Engine"
Good morning,
I'm having trouble loading any .ASC datafiles, this has previously been absolutely fine so not sure what has changed. I'm using the DASYlab.asc dataplugin which is where the files have originated from. A colleague is loading them fine on his configuration so it appears to be an issue with my setup.
Attached is the error message I get bus essentially it says "could not create script engine, please install VBS or Diadem.
(2,831 Views)
Accepted by topic author DTS_PBO
Which version of Diadem do you use? I hope reinstalling diadem, VBS might help there. Also, have you reviewed this link if you are on older versions of Diadem?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8gpSAC&l=en-US
(2,736 Views)
Hi DTS_PBO,
How are you trying to load these data files?  Are you using LabVIEW or DIAdem or SystemLink, or are you using some other tool/program?
What versions of LabVIEW / DIAdem / SystemLink are installed on that computer?
Theoretically, any of the above software would automatically install either USI (older) or UsiCore (newer), either of which would bring with it a VBScript execution engine.  The VBScript execution engine has not changed in 20 years, so this should not be a versioning issue.  I'm really surprised you got this error message and am curious about your setup and actions prior to the error pop up.
Brad Turpin
Principal Technical Support Engineer
NI
(2,701 Views)
Hi Brad, it was a very curious problem. I'm running Diadem 2020 SP1, I have been transitioning from the VBS engine to the Python engine so I can only guess I accidentally changed some settings or deleted a file...?
I have since reinstalled Diadem though and that has solved the issue fortunately.
(2,687 Views)
