DIAdem
open Import Wizard from script?
hi,
is there a way to open the import wizard from script and/or can i choose it as "dataplugin" in the DataFileLoad function?
greetings 😎
(2,982 Views)
Hello NoNameVBS,
No, it is not possible to open the DataPlugin wizard via script. The command DataFileLoad supports importing any file for which a DataPlugin exists, but it is not used as a wizard.
Greetings
Walter
(2,842 Views)
Accepted by NoNameVbs
Walter is right that you cannot use the import wizard as DataPlugin for the command DataFileLoad.
However, you can start the import wizard from script as follows:
WizardStart("WizDataPlugin")
(2,826 Views)
