06-03-2008 11:03 AM
06-04-2008 10:33 AM
06-04-2008 11:23 AM
Hi Brad,
I'm using the ASCII import wizard, upon step 3 of 3 , highlighting the time column header and changing to the date/time format previously discribed in the dropdown box.
I can email the log file, where do I find your email address ...?
Ade K
06-04-2008 11:44 AM
06-05-2008 09:50 AM
Hi Ade,
What version of DIAdem are you using? If you're using DIAdem version 9.1 or later, I'll create a DataPlugin for you that reads this file in-- that'll be superior to using the ASCII Import Wizard. If you're using DIAdem 9.0 or earlier, we'll have to go the ASCII Import route. It's possible that DIAdem versions that long ago did have a problem with some time formats, but the file you sent me could be loaded perfectly in DIAdem 9.1 or later, for sure.
Brad Turpin
DIAdem Product Support Engineer
06-05-2008 12:38 PM
Hi Brad,
I'm using DIADEM 10.2, so it should work ? maybe there's another setting I should be applying perhaps ?
I assume a data plugin is simple to use ?
Thanks for your help.
Ade
06-05-2008 02:16 PM
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
06-05-2008 02:59 PM
06-06-2008 02:24 AM
06-06-2008 11:40 AM
Hi Adek,
Here is a DataPlugin which loads your data file into DIAdem 10.2. There are a number of advantages to using a DataPlugin over the ASCII Import Wizard, so long as your data files follow a similar data file structure. To register the DataPlugin, just detach the ZIP file, unzip the URI file within, then double-click on the URI file in Windows Explorer. After that, you will be able to load your TXT data files by dragging&dropping them directly from the NAVIGATOR tree view or Search Results into the Data Portal on the right hand side of DIAdem. DataPlugins also support selective loading, register loading, reduced loading, and DataFinder indexing, so all of these immediately become available to you with your TXT files. Note also that header lines 2-4 are now declared as both File and Group properties.
Ask if you have questions using the DataPlugin,
Brad Turpin
