 itsfd
			itsfd
			04-12-2011 10:18 AM
 Brad_Turpin
			Brad_Turpin
			04-12-2011 11:55 PM
Hi Frank,
It sounds like you just dragged the Y channel by itself from the Data Portal onto the VIEW graph-- this graphs the Y channel vs. its array index on the X axis. If you select first the X channel, then the Y channel in the Data Portal, then drag them together onto the VIEW graph, then you will get the Y channel graphed vs. the X channel on the X axis.
If you post your data set, I'd be happy to create a DataPlugin for you,
Brad Turpin
DIAdem Product Support Engineer
