DIAdem
how to get ONE-x-chn out of TWO-x-chn???
Hello;)
i hope someone could help me:
I have two x-y curves. I want to divide Y-chn-vaules at a specific X-chn-value.
So I have to bring the 2nd X-chn to the values of the 1st X-chn and calculate the 1st Y-chn values(corresponding to x-value). But how can I do this? Can anybody help me? Is there a function to bring 2 curves on the same X-Value??
THX in advance!!!
BestRegards
Andreas
Message 1 of 12
(6,380 Views)
Hello Andreas!
Have a look at the ChnMapLinCalc command. This should be exact what you need!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 12
(6,378 Views)
Hello Matthias,
yes this is a good command!!! Thank you!!
...but I think I can only calculate monoton ascending functions and sometimes I some "snapback" in my function is there chance to solve this too?
Thank you in advance!!!
BR
Andreas
Message 3 of 12
(6,365 Views)
Hello Patrick!
Yes, the X channels have to be monoton ascending, but not strictly monoton ascending.
Can you please explain what 'snapback' are?!
Matthias
Matthias Alleweldt
Twigeater?
Message 4 of 12
(6,361 Views)
the curves I have are measured on a Transistor with Voltage on the X-chn and Current on the Y-chn. The Curve could look like this one http://www.simucad.com/simulationstandard/1992/apr/a1/a1_fig2.gif
Andreas
Message 5 of 12
(6,358 Views)
Hello Andreas!
In this case every channel hast to be mapped to a common base. In the following code this base a is an index channel with 1000 values (to be adapted!).
Option Explicit
' Create some snapback demo data (simplified)
Call DataDelAll()
Call ValueToChn( Array(0, 2,   4, 6,   8, 10, 12,14,15,14,12, 10, 8, 7.2, 7), "X-IN" )
Call ValueToChn( Array(1, 1.5, 2, 2.5, 3, 3.8, 4, 5, 6, 7, 8, 10,14,20,  25), "Y-IN" )
' Generate linear monotene mapping channels
Call ChnLinGen("BASE-TEMP",1,1000,1000)
Call ChnLinGen("X-TEMP",1,1000,ChnLength("X-IN"))
Call ChnLinGen("Y-TEMP",1,1000,ChnLength("Y-IN"))
' Map both channels on oneself
Call ChnMapLinCalc("X-TEMP","X-IN","BASE-TEMP","X-OUT", 1, "const. Value" , NoValue, "analogue")
Call ChnMapLinCalc("Y-TEMP","Y-IN","BASE-TEMP","Y-OUT", 1, "const. Value" , NoValue, "analogue")
Matthias
Message Edited by Twigeater on 04-10-2008 10:41 AM
Matthias Alleweldt
Twigeater?
Message 6 of 12
(6,353 Views)
Hello Andreas!
Sorry, thats solution is not enough for calculations! I will think again...Smiley Happy
Matthias
Matthias Alleweldt
Twigeater?
Message 7 of 12
(6,349 Views)
Hi
This would be very nice if you can find something for me!!!
Thanks a lot in advance!!!
BR
Andreas
Message 8 of 12
(6,341 Views)
Hello Andreas!
Sorry it took longSmiley Sad
Can you please give me somme additional info about your data. Is there another channel wich can be used to get a coreelation between two messages or is there a way to generate a parameter channel?
Matthias
Matthias Alleweldt
Twigeater?
Message 9 of 12
(6,288 Views)
Hy,
no problem;)
I have following:
Vtest = monoton increasing Test Voltage generated of the Powersupply (zB 4,8,12,...)
VDUT= resulting "Device Under Test"-Voltage at Vtest (zB at 4V-Vtest, VDUT is 3V2), the Voltage is not monotone increasing (zB Snapback, ...)
IDUT= resulting "Device Under Test"-Current at Vtest (zB at 4V-Vtest, IDUT is 35mA), the Current is not monotone increasing (could be smaller then the previous value)
What I want to do:
Divide the IDUT-channels of two measurements. To make this possible I have to bring the VDUT(of both meas.) on the same values=> so i have to interpolate the value I need with some operation...
I hope this is a bit helpful for you!
Thank you so much!!
BR
Andreas
Message 10 of 12
(6,285 Views)
