DIAdem
default configuration Report
Hello I hope I'm not creating a dump. anyway. One big quesiton about diadem: I use always the same display type: 2D graph with several curves and axes. The default font size is 3 (too big), the default curve thickness is minimum (too thin), no marker on cureves and so on and so on. Is there any way of changing the default values for that? Best regards, Brice
Message 1 of 10
(6,583 Views)
Accepted by topic author bricem13
Hi bricem 13,
Please see the DIAdem Help for predefined settings:
"Changing Standard Layouts in DIAdem REPORT
Use the default function to specify standard layouts in the function groups for tables and axis systems. To assign a user-defined 2D axis system to a button in the 2D axis system function group, complete the following steps:
1. Select the DIAdem REPORT panel.
2. Click the 2D Axis Systems group bar.
3. Right-click a button in the function group.
4. Select Predefined Setting from the shortcut menu.
5. Select Yellow as the background color.
6. Click Change.  DIAdem makes the change. If you click the button in the function group again and position the new axis system in the worksheet, the new axis system has a yellow background."
cheggers
Sascha
Message 2 of 10
(6,556 Views)
Hello I come here once more because one thing is still not solved: how do I define default curve settings like markers, thickness and so on ? Best regards, Brice Méalier
Message 3 of 10
(6,403 Views)
Hi bricem13,
To my knowledge it is not possible to configure default properties for new curves dragged from the Data Portal onto a graph in DIAdem.  I agree that this would be an excellent feature and have officially asked R&D to consider this for the future.
Brad Turpin
DIAdem Product Support Engineer
Message 4 of 10
(6,391 Views)
Hello Brad, It could be a good thing... Also there is no way of selecting several curves and changing their settings, which turns into a nightmare when several curves need to be changed... Best regards, Brice
Message 5 of 10
(6,376 Views)
Hi Brice,
Configuring multiple curves simultaneously is a feature that my counterpart PSE, Walter Rick in Germany, is already championing, so I am quite hopeful that we will see something on that front in the next couple of years.
Thanks for the feedback,
Brad Turpin
Message 6 of 10
(6,367 Views)
Hi Brad,
I was wondering if this old issue has a solution.  I just encountered the desire to have the 2d graph default to my preferences, not Diadems.  For instance, legend configured the way I like it, no Y-axis labels, etc.  It's frustrating to have to keep changing these setting for every new graph.
Message 7 of 10
(5,178 Views)
Sorry Jeff,
DIAdem 2012, just released this month, does not offer any new features in this regard.  One thing to note here is that for several versions now you can apply some of the graph settings from one graph to all the others on that sheet and other sheets.  That might help, though it's not what you're asking for.
Rest assured that the feature request has been registered with R&D and has my full support.
Brad Turpin
Message 8 of 10
(5,169 Views)
I can use the predifined settings to get the plot to look as I want, but is there a way to make sure it uses these settings when I use the transfer to report button from view?
Brian
Message 9 of 10
(4,885 Views)
Hi Brian,
The only way to customize the VIEW to REPORT transfer is to edit the result you get in REPORT afterwards (interactively or programmatically) or to reprogram the whole transfer yourself.  I have done some of both, but the best approach is stronly dependent on the use case(s) you have in mind.
Brad Turpin
Message 10 of 10
(4,862 Views)
