‎06-17-2015 08:02 AM
Is there a way to create a datafinder server connection in script? I have a file location that needs to be typed in (you can't find it by going through folders), and want to know if there are other methods of adding server connections.
Artemis
‎06-18-2015 03:13 AM
‎06-18-2015 08:00 AM
I'm using My DataFinder, and was looking to add a search area.
‎06-18-2015 08:18 AM - edited ‎06-18-2015 08:19 AM
I was able to use the following which fixed my problem,
Call Navigator.ConnectDataFinder("My DataFinder").GetSettings().SearchAreas.Add()
Call Navigator.ConnectDataFinder("My DataFinder").Indexer.IndexFolder()
But now I'm wondering if there's a way to check if a search area already exists in the datafinder.
‎06-19-2015 06:53 AM
Hi Artemis,
See if this approach works in your DIAdem version:
Set DataFinder = Navigator.Display.CurrDataFinder.GetDataFinder()
Set Settings = DataFinder.GetSettings()
Found = FALSE
FOR Each SearchArea In Settings.SearchAreas
IF LCase(SearchArea.LocalPath & "\") = LCase(sFldr_client_rw) THEN Found = TRUE
IF LCase(Right(SearchArea.LocalPath, 20)) <> "\documents\client_rw" THEN
Call Settings.SearchAreas.Remove(SearchArea.Name)
END IF
NEXT ' SearchArea
Brad Turpin
DIAdem Product Support Engineer
