DIAdem
channel namming system
Hi everybody
When using this command:
DataFileLoadSel("../myfile.dat","DAT","Fernlicht\Lichthupe")
i got an error , even though I know that this channel really exists in myfile.dat and when I load from the selective data load in the Navigation Panel
i can actually see the name of the channel as is Fernlicht\Lichthupe
but once the channel is loaded   other functions work well
for example :  k=CHD(10, "Fernlicht\Lichthupe")
I guess the problem is the "\" in the name , how can i load the channle wiout changing ist name
Thanks in advance
Message 1 of 8
(4,429 Views)
Hi Arkangel,
I've tried the following command:
Call DATAFILELOADSEL("Drive.dat","DAT","Drive/Geschwindigkeit","")
It worked fine. Do you use the latest service pack of DIAdem?
Greetings
Walter
Message 2 of 8
(4,425 Views)
Hi Walter
I have downloade the SP2b  and still have problems  when I use the "\" ,  but not when , like in your case, it is used the "/", or should I change the names of my channels ,
Thanks in advance
Message 3 of 8
(4,414 Views)
Hi Arkangel,
Sorry I didn't recognize the "\" character. The delimiter between group name and channel name is always the "/" and not the back slash. So with a regular slash it should work fine.
Greeings
Walter
Message 4 of 8
(4,411 Views)
Hi Walter
sorry for the annoyance 🙂
I dont see why this line gives me an error ,  as U said , this should be a valid name , i use the "\" to avoid problems with the group-channels separator "/" and still have the error , DD8x ( when using the Diadem i got this error when the channel is not found ), and I got this report from another machine , then I tried here and in both cases it seems to the same problem
call DataFileLoadSel("D:\usr\Round\load\5-18-2005(7_47_08(AM))-1000ms.dat","DAT","[1]/MMI HK CD\TV")
what it is confused is, once the channel is loaded ,all the other commands work fine ,
Thanks in advance
Message 5 of 8
(4,405 Views)
Hi Arkangel,
I've done some tests, but it works fine every time.   I can load partially a channel named "Spe\ed" without any problems.
Example:
call DataFileLoadSel("Drive2.dat","DAT","[1]/Spe\ed")
Sorry, but I don't know what happens. To go in more details I need a reproducible environment like script files, data files etc. - only than I could have a chance to find the reason for the problem.
Greetings
Walter
Message 6 of 8
(4,395 Views)
Hi Walter
In my machine the script ,  the second line works but not the first one , I tried to see any difference between the names in the .dat file , apart form the "\" are the same
this i16 file contains 5 channels 3 "normal"  and 2
My diadem installation is 9.10.2345 SP2b
Thansk so much in advance
script:
call DataFileLoadSel(":\\5-16-2005(10_25_31(AM))-500ms.dat","DAT","[1]/Sitz vor\zurueck")
call DataFileLoadSel(":\\5-16-2005(10_25_31(AM))-500ms.dat","DAT","[1]/ACC Set")
Message 7 of 8
(4,390 Views)
Dont anwser this question Smiley Wink i found out what my error was
anyway thansk
Message 8 of 8
(4,362 Views)
