DIAdem
calculation problems
i wanted to write a script for multiple calculations where i should be able to change the inputs and outputs at the beginning of my script.
The problem is, if i use the easiest way of tha calculation script i can't define variables or i don't know how.
this was my try
Call Calculate("Ch(""[2]/pa_Titel"")= Exp(456 - (123 / (Ch(""[2]/T_LL_Ansaug"") + 789)))",NULL,NULL,pa_Einheit)
the problem is i want to assign another name to pa_Titel and T_LL_Ansaug at the beginning of my script.
like this
Dim tL
Dim pa_Titel
Dim pa_Einheit
pa_Einheit = "mbar"
pa_Titel = "[2]/Wasserdampfsättigungsdruck"
tL = "[2]/T_LL_Ansaug"
Call Calculate("Ch("pa_Titel")= Exp(789 - (456 / (Ch("tL") + 123)))",NULL,NULL,pa_Einheit)
 but that didn't work.
then i tried this
Dim tL
Dim pa_Titel
Dim pa_Einheit
pa_Einheit = "mbar"
Dim  CurrSymbols(2), CurrValues(2)
CurrSymbols(1) = "pa_Titel"
CurrSymbols(2) = "tL"
Set CurrValues(1) = Data.GetChannel(pa_Titel)
Set CurrValues(2) = Data.GetChannel(tL)
Call Calculate("pa_Titel = Exp(789 - (456 / (tl + 123)))",CurrSymbols,CurrValues,pa_Einheit)
 the problem here is that the channel pa_Titel doens't exist and that the output should be called Wasserdampfsättigungsdruck and not pa_Titel.
i could do it with the calculation manager but i have many calculations and it's easier to do this in a script.
can you tell me how to do this.
Message 1 of 12
(6,120 Views)
i just saw that the output of the last version IS called Wasserdampfsättigungsdruck. but it only works if the channel exists.
i think i only have to change this part
i could create a Channel with the right name before i use the calculation but is there not a better way to do this?
the Problem is if i create a channel with
Call Data.Root.ChannelGroups(2).Channels.Add(pa_Titel,DataTypeFloat64)
 i get a channel which is called [2]\Wasserdampfsättigungsdruck in the group 2. is there another way to do my calculation?
Message 2 of 12
(6,114 Views)
Hello Norman,
It seems that the string syntax in your calculation function is not correct. If you're using variable for the channel names you need to set the correct quotation mark syntax and concatenate the string fragments. But I would like to point to the Calculation Manager in DIAdem-ANALYSIS which is a more powerful and easier of use tool for calculations like yours. If you once set-up your formulas in the Calculation Manager you can change the input channel names very easy. In the following example the first input channel of a formula (which is defined in a formula group) is changed.
dim oMyCalc
call CalculationSet.Load("My Calculation Set")
set oMyCalc = CalculationSet.CalculationGroups("My Calculation Group").Calculations("My Calculation")
oMyCalc.Inputs(1).Reference.Channel = "My New Channel"
oMyCalc.Run
 I hope this can help you
Greetings
Walter
Message 3 of 12
(6,111 Views)
Hi Walter,
thanks for the hint with the calculation manager but it's easier with a script. i don't need automatically change the calculations. in a while a need to change the inputs from the calculations and there are about 100 calculations. it's faster to do this in the scripting part.
i tried your tip with concatenating the strings but i didn't get it to work. i think i made a mistake with the quotation mark.
this is my calculation. and the error is ')' expected.
Call Calculate("Ch(""[2]/"& pa_Titel &")= Exp(123 - (456 / (Ch("""& tL & """) + 789)))",NULL,NULL,pa_Einheit)
can you help me to find my mistake?
Regards, Normann
Message 4 of 12
(6,098 Views)
the solution was
Call Calculate("Ch(""[2]/"& pa_Titel &""")= Exp(123 - (456 / (Ch(""[2]/T_LL_Ansaug"") + 789)))",NULL,NULL,pa_Einheit)
thanks for your help Walter.
Regars Normann
Message 5 of 12
(6,091 Views)
Accepted by topic author Normann
Hi Normann,
The following should work.
Call Calculate("ch(""" & pa_Titel & """) = Exp(789 - (456 / ( ch(""" & tl & """) + 123)))",Null, Null, pa_Einheit)
The calculation manager is of course designed to be used in scripts - but it is more easy to create the formula and to reuse it in scripts or interactively as often as it is needed.
Greetings
Walter
Message 6 of 12
(6,090 Views)
Ich bin gerade fertig geworden mit meinem Skript und wollte es laufen lassen aber leider funktioniert es nicht. Das Problem scheinen Double Werte zu sein die ich eine Calculation reinpacken will. geht das nicht oder muss ich es anders machen?
Dim zahl1, zahl2, zahl3
zahl1 = 4.5
zahl2 = 3.7
zahl3 = zahl1+zahl2
Call Calculate("Ch(""[2]/test"")="& zahl3 &"",NULL,NULL,"")
 wenn ich 4.5 und 3.5 addiere geht es aber wenn das Ergebnis ein Double Wert ist dann kommt immer der fehler "anweisungsende erwartet" muss ich Zahl3 irgendwie als Double definieren wie in VBA oder kann ich nur strings und integer in eine Calculation packen?
Message 7 of 12
(5,985 Views)
ich habe gerade die Str-Funktion gefunden, damit funktioniert das umwandeln in einen String. Ist das die einzige Möglichkeit mit der ich berechnete Größen in einer Calculation verwenden kann?
Message 8 of 12
(5,979 Views)
Hi Normann,
If you want to use a variable in the Calculate expression, then you need to make that variable a global variable with GlobalDim instead of just Dim.
Dim zahl1, zahl2
GlbalDim "zahl3"
zahl1 = 4.5
zahl2 = 3.7
zahl3 = zahl1+zahl2
Brad Turpin
DIAdem Product Support Engineer
Message 9 of 12
(5,972 Views)
Hi Brad,
if i use your code i get the same error. i corrected the GlobalDim command.
can i compute with global and normal variables?
like
Dim zahl1, zahl2
GlobalDim "zahl3"
GlobalDim "zahl4"
zahl1 = 4.5
zahl2 = 3.7
zahl3 = zahl1+zahl2
zahl4 = zahl3*zahl1
 it would be nice if that works. if not i have to convert every calculation which is not done with in a Call Calculate with the Str Command.
Normann
Message 10 of 12
(5,968 Views)
