DIAdem
adding multiple channels
Hi there,
I'm trying to add a number of channels together in Diadem 2015 using the following command :
Call ChnAdd("[4]/SA4_14 N","'[4]/SA2_16 N' - '[4]/SB5_3'","[4]/COMFORT totalled")
There a a total of 46 channels within the group, on some logs the script runs ok, but on others I receive the warning:
Error in <T24STEP4_TOTALLEDFUSES.VBS> (Line: 10, Column: 1):
Values in line 135-4, are too high.
The values do not appear to be noticeably different, so do not know why it's in error..
Perhaps I need to consider an alternative method for totalling channels within a group.
Any help would be appreciated.
AdeK
(5,310 Views)
Hi AdeK,
I need an example to reproduce the problem.
I tested the general behavior with this script:
dim oFirstChn, oChnList
set oChnList  = Data.GetChannels("MyChnGroup/*")
set oFirstChn = oChnList(1)
call oChnList.Remove(1)
call chnadd(oFirstChn, oChnList, "Result")
This works fine, even if channels don't have the same length.
I tested it in DIAdem 2015
Greetings
Walter
(5,303 Views)
Hi WalteR,
Thank you !
This seems to works fine !
I will add all new channel groups to the script as below :
setoChnList = Data.GetChannels("[2]/*")
setoFirstChn = oChnList(1)
calloChnList.Remove(1)
callchnadd(oFirstChn, oChnList, "[2]/CHASSIS totalled")
setoChnList = Data.GetChannels("[4]/*")
callchnadd(oFirstChn, oChnList, "[4]/COMFORT totalled")
(5,295 Views)
