DIAdem
add the same channel
how can I add the same channel from Group1 into Group2 by coding?
(5,885 Views)
Sergio,
' Define the Channel to copy
Dim
oChnToCopy
Set
oChnToCopy = Data.GetChannel("Group1/CHANELNAME")
' Define the target Group
Dim
TargetGroup : Set TargetGroup = Data.Root.ChannelGroups("Group2")
' Add he channel to the group containing the properties
TargetGroup.Channels.AddChannel(oChnToCopy)
You just need to defined the Channel Name to copy and the target group name.
(5,881 Views)
thanks for the quick response Naoa,
This is what I do:
I select the channels Ex.(channel1,channel2) from the listbox and click a go button and the channels display into group1 on the dataportal, but when I selected channel2 and channel3; the only channel the it appears into group2 is channel3, I need channel2 in group2 as well.
(5,879 Views)
Can you clarified more, i did not understand well the problem.
(5,876 Views)
I got the Solution.
(5,872 Views)
