DIAdem
Showing results forĀ
Search instead forĀ
Did you mean:Ā
XTable Cell Alignment Issues
Hello all:
I'm having an issue with my XTables.  I want my data to be center aligned within each cell, but "cell.Alignment=1" keeps returning the following error: "Object doesn't support this property or method: 'Cell.Alignment'."
The interesting thing is, however, that the header row for the columns (row 0) center aligns properly, without throwing an error.  Everything besides that remains left aligned.
I've attached a screenshot of my code.  Any assistance would be greatly appreciated!!!
Alex
Message 1 of 13
(3,987 Views)
Message 2 of 13
(3,984 Views)
gskylr:
Thanks for the response.  Looks like that would work for vertical alignment, but I'm looking to center the text horizontally within the cell.
Any thoughts?
Alex
Message 3 of 13
(3,981 Views)
Is any of your columns not of "Text" type?  they could be ListBox or something else which does not support "Alignment" property?
Message 4 of 13
(3,971 Views)
gsklyr:
No, they are all "Text" types- I'm putting values from channel properties as well as data from data channels into the cells.
I'm still stumped on this...
Alex
Message 5 of 13
(3,943 Views)
The return value of the function Val() is of numeric type and you are assigning it ti a cell.text.  Could it be messing with things?  Maybe you need to convert it back to string
Message 6 of 13
(3,940 Views)
Unfortunately, that is still throwing the same error.  Any more thoughts?
Message 7 of 13
(3,924 Views)
At the top of your EventValGet put the line:
Call MsgBox(Cell.Alignment)
You will be able to see the order of execution and understand when exactly it fails
Message 8 of 13
(3,916 Views)
The issue appears to start right after inserting the column headers.
I have the following error: "Object doesnt support this property or method: 'Cell Alignment'."
It throws that error in the msgbox line that you suggested.
Message 9 of 13
(3,903 Views)
Maybe it can't align something that is not populated?  looks like this function runs at initialization, how about using Alignment property only when cells have been initialized/populated?
Message 10 of 13
(3,900 Views)
