DIAdem
What is the DIAdem equivalent of "Continue For"?
I have a For loop, that allows me to process multiple group from different files at once, that has a "If..Then" check at the beginning of the loop to make sure each individual group can actually be processed. If a group fails the check, I simply want to be able to skip to the next iteration of the For loop right there.
I know in VBA I would use "Continue For", how would I do this in DIAdem?
If x <> 0 Then
  x = ChV(x,"Group/Channel")
Else
  Call ErrorHandler("Can't find x.")
  Continue For
End If
  Thanks.
(5,243 Views)
Accepted by topic author Kevin_McG
There is no continue.
I would move the code to a sub and use exit sub.
dim i : For i=1 to 10
 DoWork i
Next
Sub DoWork(i)
    If 2 = i Then
      Exit Sub
    End If
end sub
(5,236 Views)
Ah, ok.
I can do that. Thanks.
(5,234 Views)
