ā10-22-2007 09:06 AM
ā10-23-2007 11:02 AM
Hi punkmonkey,
The SUDialog Editor's intellisense unfortunately only goes down one level, but the rest of the object levels still exist and can be read and set with the standard "dot" notation. You can find the rest of the object structure in the Online Help.
Which control are you talking about specifically?
Brad Turpin
DIAdem Product Support Engineer
ā10-23-2007 12:26 PM
ā10-24-2007 09:42 AM
Hi punkmonkey,
But the Checkbox control doesn't have columns and rows. So you must mean the column and row of the Table control that this particular checkbox is in. Are you using DIAdem 10.2, and are you using the new Xtable control? How are you getting the Checkbox control object? If it's in a Table control, you must already have the Table cell in order to retrieve the Checkbox object-- you should be able to get the row and column from the Table cell.
Brad Turpin
National Instuments
ā10-24-2007 10:01 AM
ā10-24-2007 02:20 PM
Hello punkmonkey!
As far as I know are these properties only available at design-time and not at run-time!
A solution is to write the index in the 'tag' property and use this at run-time. It is a string but you can cast to an integer!
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
