DIAdem
Unzip for DataPlugin
I try to manage zip files with the DataFinder. I tried to use the code below, but it didn't work. I always get the message: Type mismatch: 'Unzip'
There is only one csv file in the zip file. I am using DIAdem 2017 SP1 and it didn't work with DIAdem 2017 neither.
Has someone already had an experience with that?
Thank you in advance
Tansu Özel
Code:
Sub ReadStore(FileName)
  Dim TempFolder
  TempFolder = AutoRemove.CreateFolder()
  Dim FileList
  FileList = Unzip(FileName, TempFolder)
  Call Root.ImportStore(TempFolder & FileList(0), "my_csv")
End Sub
(2,306 Views)
Accepted by topic author toezel
Make sure you switched your plugin to "Filename only plugin".
else you will get an object instead of a filename.
(2,284 Views)
Thank you AndreasK, it works!
(2,281 Views)
