DIAdem
Obsolete Command: ChnPropValGet
Hello everybody,
I'm looking for values I was able to extract from ChnPropValGet. For being more precise, it's "sourcedatafilepath" and "sourcedatafilename".
All I get from Data.Root.Properties is sourceoriginalname resp. name, which corresponds to Data.Root.Name.
I have no use for that one - I need my path.
Any ideas how to get my path on DIAdem 2017/2018 out of my data in portal?
Yeti
(2,910 Views)
Accepted by topic author ChaosYeti
Hi Yeti
You are looking for a channel property not for a root property, because you could load data from differnt soures to the Data Portal.
So try for example:
Data.Root.ChannelGroups(1).Channels(1).Properties("sourcedatafilepath").Value
You can also drag and drop any property from the Data Porta to Script to get the correct syntax.
Hope this helps
Winfried
(2,898 Views)
Call LogfileWrite(datafilepath)
(2,897 Views)
Hi Winfried,
a thousand thanks!!
Yes, you are right. I fear I stared too long at it to not notice that...
The new help (v2018) is not really a help... Tab "Index" contains 39 entries. Or I have to find another way to use it.
You helped me a lot!
-- Yeti
(2,895 Views)
