DIAdem
USB-CAN 8473 and Diadem/MAX
I have a USB 8473 which I would like to use with Diadem.  Under Max I can see the devices and create channels which refer to these two devices.  However in Diadem all the channels are visble but not available (red Xs).  Any ideas here as to what I am doing incorrectly here?
Jeff
(4,040 Views)
Hello Jeff,
there are two APIs for NI-CAN, the channel API and the frame API. The DIAdem driver for NI-CAN is based on the channel API of NI-CAN. Unfortunatelly this API is not supported by the USB-CAN modules. These modules support only the frame API of NI-CAN. Thus DIAdem does not support the USB-CAN modules.
Unfortunatelly in MAX you can assign a CAN message to a USB-CAN port so that you might think everything is fine with this setup. But if you launch the Testpanel, you will see that you cannot run it on the USB-CAN ports.
Rainer
(4,023 Views)
Thanks Rainer
are there any future plans to support USB-CAN with Diadem? If so, when?
Jeff
(4,010 Views)
Hello Jeff,
Yes, we plan to develop a divice driver for USB-CAN hardware, but currently we don't have a target date for it.
Greetings
Walter
(4,006 Views)
Thank you for the reply.  Could anyone please tell me which CAN cards are supported by Max/DiaDem?
Jeff
(3,977 Views)
